Which slick should I get
I bought a pair of 28x11.5x16 ET Street slicks,. I have a Dana 60 with 4.10 gears and will be launching on a 150 shot with around a total of 500-520rwtq.
After talking with some friends they think the 28 is to big and will rob to much gear. The guy I bought them from hasn't shipped the 28s yet, and also has a pair of 26x10.5x16 ET Street slicks, would those benefit me more in all around ET?
The car is a 96 M6 TA
a 27 would be better for your setup, but a 28 should work just fine esp you being on the gas off the line you are gunna need as much meat as you can get. if u went up to a 4.30 gear the 28's with a 150 would be the most optimum setup.
but to answer your question, you can run the 28's but 27's would be better with the 4.10's.
You should get adjustable LCAs anyway, regardless.
You will have to trim some of the fender, but only you will ever know that you did it. It is not cosmetically damaging.
