how much did you guys lower?? how much is too much with longtubes??
looking to lower my car pending arrival of new wheels, wondering what you guys went with and how much did you lower...car will have TTM's 17inch all around..thanks
Longtubes are the least of your clearance worries unless you're running SLP's. The collectors are the highest point in my entire exhaust system. For the most part, if you're running y-pipe & catback you can get away with more of a drop than with duals. I'm dropped ~1.75" with duals and I've lightly scraped my h-pipe crossover a couple times.
I have the prokit and SLP LT's, a bad combo anyone should tell you. But I love it. But my car is not speed bump friendly. So you need to think out the pros and cons. Prokit = awesome aggressive look.
Eibach Prokit or Sportlines
Originally Posted by 98hardtopSS
thanks alot guys that helps alot...i think i am going to order either the 1.75 from eibach
i appreciate the pics, that helped alot!!
[IMG][/IMG]
[IMG][/IMG] [IMG][/IMG]
that white ss looks wicked good......what are those 18's??my buddy has those on his 97 z. i like the look of the sportline but i am curious to see how low it will be without that 1 inch spacer...regardless i am bidding on a set right now to find out the hardway
ChoiceCam00... How in the h3ll did you get your rebels to sit in so far in the front?!? Mine stick out a bit more than yours. I've got the 18's.
Anyway, SLP LT's are TeH SUCK w/ drop springs!! The Y-pipe is most of the problem, it needs to be tucked up a LOT on the pass side. The collectors sit a bit low too.. I've got 18" AR Rebels w/ Eibach ProKit. 1" drop is plenty on our cars....IMHO...
Front wheels
