will zo6 replica 18x 10.5 fit?
hey guys ive been looking at the zo6 replicas 18x10.5 for the rears. does any body runs these? i read the sticky and up top and it mentioned something about a bfr mod or something like that, i have no idea what is accronym means. if they do fit, what size tires? thank you
You can also use a set of 1/4 inch spacers on the hubs to give you a little more clearance. If you take this route, I recommend that you get some longer wheel studs. If you keep the stock studs you are only going to get 4-5 turns per lug nut.
