Everyday driver tires?
Old 11-20-2006, 01:08 AM
LS1CAMAROSSBLK's Avatar
Default Everyday driver tires?
what would you guys recomend for an everyday driver tire. im not really looking for performance, unless it for rain. they are going to be going on the stockk ss wheels, just need some recomendation i really don't trust the tire guys at the shops around here.
Old 11-20-2006, 07:47 AM
Ragtop 99's Avatar
take a look at tirerack.com. They have a number of catagories that you can select from that best match your need. Then check out the survey results and see which tires are good enough and cheap. This should get you started.
Old 11-20-2006, 07:49 AM
BIG_MIKE2005's Avatar
I really like my KDWS tires. I have had them on now for a year & daily drive my car. Tread wear is great & so is wet/dry traction.
Old 12-02-2006, 08:40 PM
ArrestMeRed99Z28's Avatar
I am also looking for an everyday tire, any one have thoughts? Stock tire size for a Z 28 Rim, 235 245, 16inch
Old 12-02-2006, 10:29 PM
rocket22's Avatar
BFG KDWS,stock tire size is 245/50/16
Old 12-03-2006, 09:32 PM
CaMaRo67RS355's Avatar
when i got my car (used) it had Bridgestone Potenzas on it 275-40-17 they are a good everyday driving tire but handles real well. but my g/f had to replace her tires and i put some KDW's on hers.
Old 12-03-2006, 10:01 PM
speed_demon24's Avatar
GSD3's are hands down the best wet/dry tire.
Old 12-04-2006, 11:32 AM
01bird58's Avatar
Can't go wrong with GSD-3, especially if you see a lot of rain.
Old 12-04-2006, 01:53 PM
farnoush's Avatar
If your looking for a quality tire go with the BFG KDW, if you want something cheap go with fuzion zri's.
Old 12-04-2006, 02:01 PM
highwaywonderland's Avatar
I have Michelin Pilot sport A/S high performance all season tires. They seem to be very good in the rain and pretty good in the snow too. They are a little pricey. I paid 178.00 per tire installed.
Old 12-04-2006, 02:15 PM
burningsquirrels's Avatar
the kumho ecstas that are on my z right now work plenty fine, should be well under 100 each installed.
