BFG T/A drag radials kick butt
hey guys i just used these tires on my 02 ws6 with a size 315, and they rocked. i launched the car at 4500 rpm and they hooked so good i pulled the wheels off the ground and got a 1.55 60ft. and ran a 10.92@127 mph. the car has about 550rwhp and didnt spin. when i tried to launch at 5000, the tires spun but still managed to pull the wheels. these tires are amazing for being a drag radial. also the car is a 6 spd. with a spec stage 3+ clutch.
Jon
Jon
Thanks for the comments guys, even with the 18" rim and the 30 profile with very little sidewall it still hooked up as good as it did. the only think i noticed was that after the front end came down, i had some tire hop. im not sure if that had to do with the pinion angle of the rear or because i had such little sidewall. i have a adjustable torque arm, and it set pretty level, but idk if it set the way its supposed to be. thanks
Jon
Jon
thanks for the props, for the motor i have a relseeved 455 ci ls1 motor fully worked. afr heads. about 625-650 hp. its all motor too. moser 12 bolt, and a kooks 3" true dual exhaust system. if you need any opionions on mods or any other questions feel free to ask away.
Jon
Jon
Jon
Jon
how would you guys compare these to nittos? i had a set of bfg's on my A body quite some time ago they wer good but damn, hangin the front tires on a stick car 1.55 60'
do you have a two step
very bad *** maybe Ill keep my t56
Jon
Jon
Originally Posted by Zach@Texas-Speed
way better than nittos
i had the old ones on my Olds i know they were soft didnt last the longest and didnt hook as good as my 2 ply et streets but nice for DD
Originally Posted by Colin91Z
Exactly what size are those? I just bought a set of BFG drag radials in 295/35-18 ...I hope they work out for me as they did for you
Originally Posted by B18CYA
are these the directional ones or the old school ones with the solid patch in the center
in the 315-30R18 size.... since it's the only 18" 315 DR tire BFG makes
Jon
Jon
i think i need to change my drawers
that is damn impresive
