widest tire for a drag radial
Old 12-23-2006, 10:57 PM
ls1chris's Avatar
Default widest tire for a drag radial
well i love to look of drag radials and would love to put a set of 15 or 16 inch on my car but i really dont want skinnies up front. is their anyway i can runa decent size tire up front with a drag radial like a weld or prostar any kind of drag wheel for that matter.the back will be fitted with a nitto 555 drag radial but just curious is i have to have them small tires up front .cuz i dd my car i just want that look of the drag wheels
Old 12-24-2006, 01:01 AM
Asmodeus's Avatar
you can get 15x7 fronts in weld's.. put a 215-225 on there.
I think you can get drag radials up to 335 or 345 I'd have to look but they do go bigger than 315.
Old 12-24-2006, 02:07 AM
GTP PWR's Avatar
I have 325's on mine and can still go wider. mounted on 15X10's
Old 12-24-2006, 05:37 PM
ls1chris's Avatar
aslo guys what would be the widest width i could go for the fronts without a lot of grinding ive heard go with a 5 or 7 inch and just put a regular tire on it but i dont knwo what yours input
Old 12-25-2006, 12:32 AM
Asmodeus's Avatar
https://ls1tech.com/forums/wheels-tires/120716-wheels-tires-everything-you-should-need-know-here-must-read.html
that should help, gives tire size vs rim width in the first post.
Old 12-25-2006, 10:55 AM
The1N_only's Avatar
i run a set of 325/50/15's out back
