weld draglites
A 15 X 10 Will Require A 7.5 Inch Back Space. My 15 X 8's On My Lt1 Required A Very Minimum Amount Of Grinding, Mainly At The Top Outside Corner Where The Fins Blend Into The Top Surface Of The Rotor. I'm Sure You'll Have To Do The Same. Very Easy Job Using An Angle Grinder.
