2006 Vette C6 rims on WS6?
2006 Vette C6 rims on WS6? Yes, but do you have pics of Z06 rims?
Will a set of 2006 Vette C6 rims fit on a WS6?
i got the set for about $870 shipped i believe. i love them, i have a picture but it's just from my cell phone. when it gets warmer i'll clean it and get some real pictures w/ my digital camera. i don't run spacers but you probably could.
for tires i got bfgoodrich kdw2 275 and 295/35.
http://www.skulte.com/
1.25" adaptors for the rear (19x10"), fronts (18x8.5") should fit without adaptors.
Last edited by Silvrshark; 01-31-2007 at 05:08 PM. Reason: forgot to pu adaptors for rear only
From what I've found the factory rear 19x10 offset is 79mm. Which is about an inch more than you need. So a 1 1/4" adapter would give you an offset of 48mm. That is about what you need. I would personally wait until you get the rims and then see if you want a 1.25" or maybe a 1.5" adapter to push the rears out a little more to make it look better.
There's also an Ebay store that has hubcentric adapters called ezaccessory and cost about $60 pr.
Originally Posted by desertLS1
what about on a camaro? anyone have pictures?
https://ls1tech.com/forums/showpost....1&postcount=47
