Those who can't rotate your tires-- Come in!!
Old 02-12-2007, 12:19 PM
What's a Sticky?
97MysticZ's Avatar
Default Those who can't rotate your tires-- Come in!!
I'm gonna be getting some TTII's for my car. Right now I'm stuck on if I wanna get the wider wheels in the back or not. This car is my daily driver, and doesn't see much track time. I'm concerned that tires won't last long not being able to rotate them. How much mileage are you all seeing? I'm not concerned about actual mileage as much as not being able to rotate the fronts to the rear, and then they start to cup and ride like ****. What are you all experiencing?
Old 02-12-2007, 12:26 PM
SSilverSSurfer's Avatar
you can rotate them side to side, which means you'll have to break them down if there directional, unless you get assymetrical tires.
to be honest with as much driving as i did back when it was a daily driver i still havent replaced my front tires and that was 3 years ago, and i still have tread left. tires are chopping out a little but not enuff to cause any problems, the rears are 315's and they wear flat across with no problems, proper air will also have an effect on the wear. let me know if you need any more help
Old 02-12-2007, 12:51 PM
What's a Sticky?
97MysticZ's Avatar
Cool thanks I work at a shop, so the pressures will always be right and the alignment will always be dead nuts on.
What kind of 315 tires are you all running in the back?? I'm looking for something kind of cheap. I know I can get Sumitomos for $99 but I'd like something a little better. Is there anything around the $200 per tire range??
Old 02-12-2007, 01:27 PM
im runnin nitto 555r's and they do better in the rain than the stock tires did. i paid like 28x.xx for 2 of them
Old 02-12-2007, 01:34 PM
JGKadell's Avatar
The sumitomo is junk. They are VERY skinny 315. My old BFG 285/40/17 KDW was almost exactly the same width.
Old 02-12-2007, 01:38 PM
faust's Avatar
i run 315 bfg drag radials out back and 275 kdws up front i wasn't concerned about rotation since the rears will wear out long before the fronts ever would
Old 02-12-2007, 07:30 PM
What's a Sticky?
97MysticZ's Avatar
I just don't know about running a drag radial out back because its my daily driver and it will see rain. Plus, I don't go to the track much at all. But the drag radials (BFG & Nitto) are about the only tires I can afford in a 315/35/17
Where did you get those at?
Old 02-12-2007, 07:33 PM
erikthegoalie's Avatar
tt2's staggered here...no problems, i run nitto DRs in the back and shitty japanese ***** up front haha
Old 02-12-2007, 07:57 PM
faust's Avatar
while i understand economics play a big role in things, i personally can't stand when the fronts and rears are mis-matched brands if i had bought nitto dr's i would have put 555 up front. to my eye it just looks ghetto
Old 02-12-2007, 08:06 PM
99zmaro's Avatar
im running riken raptors they are made by michelin they are pretty good as far as i can tell they pick the littles rocks up and are nice and sticky but they are also cheap i use them for my (kinda) daily driver z28 im impressed with them
Old 02-12-2007, 09:01 PM
N2O-ARMD's Avatar
I was running nitto dr's then switched to Sumitomo HTR Z just for the simple fact that I like to club the sh## out of my car burn outs and such I just couldn't justify the caost of the nitto's compared to the sumitomo they don't handle to bad. And I have done numerous burn outs on them and they seem to be hanging in there pretty well. They didn't balance up very well though thats the only problem that I've had with them. I haven't had any problems with cupping on any of my tires though I have roughly 15k miles on them, with no rotation.
Old 02-12-2007, 09:50 PM
michaelg589's Avatar
true that ... BFGs all around here.
Old 02-12-2007, 10:18 PM
thunderdan74's Avatar
Aisian tire companies measure the tread with at the tread. US companies measure it at the rim bead.
I run BFG KDW2 front and rear with 245/40 18 x8.5 front, 295/35 18x9.5 -35mm offset Front & rear.
Old 02-12-2007, 10:44 PM
the drags were my daily drivers and they wre great in the rain, that price was my employee price at the discount tire
Old 02-13-2007, 12:20 AM
1LoudTA's Avatar
haha me too
Old 02-13-2007, 12:33 AM
Same tires as me. except I'm running 275-35 up front on a 9.5" wheel and a 295-35 in the rear on a 10.5" wheel
Old 02-13-2007, 07:25 AM
BlackHawk T/A's Avatar
If you're like me, you can't rotate drag radials to the front so it doesn't matter
Old 02-13-2007, 12:14 PM
What's a Sticky?
97MysticZ's Avatar
How do you like your setup? Do you ever do any driving in the rain?
Old 02-13-2007, 12:54 PM
c0ncEpT's Avatar
Don't be afraid of drag radials. I ran my Nitto 555R until the center was completely bald and I drove it in the rain a few times and I didn't have a single problem with them. I loved how they looked and I like how the hooked even better.
Old 02-13-2007, 12:58 PM
What's a Sticky?
97MysticZ's Avatar
How many miles are you all getting out of the nittos? Please state to if its just driving or including burnouts and stuff like that too.
