Weld Pro-Star/Draglite ?'s
Old 02-13-2007, 12:03 PM
eLTwerker's Avatar
Default Weld Pro-Star/Draglite ?'s
Summit need you to measure your backspacing to get drag rims. Is there some conversion factor or something b/c the backspacing is different for the front and back wheels in LT1 f bodies, but if I measured the backspacing using stock wheels, wouldn't the numbers all be the same?
Also, what size tires would I use for 15"X6"?
Also, why do the front wheels need a spacer and the rear wheels do not?
