TTMs with C5 brakes?
Anyone tried it? I'm thinking about putting some Anthracite Torq-Thrust Ms (in 17x9 w/+45mm offset) on my 95 Formula, but I want to do the C5 Front Brake conversion in the near future.
Anyone have this combo?
Byrdman
Byrdman
The wheels should fit no problem. I have the Baer GT+ kit which is practically the same (except I have larger rotors) on my 95 bird. I also have stock ws6 17x9 wheels on the vehicle which have a 50mm offset and I have no problems at all. A 17in wheel or larger is required when running the C5 brake kit, so you are good there. Along with that the 45mm offset will give you more than enough clearance between the wheel and caliper.
Originally Posted by Phoenix 5.7
well, TT2s do not work with the C5 setup so i would be wary of the TTM working
The spokes of a TT2, curve sharply inwards and contact the C5 caliper. I have seen cars where they have run a small spacer, and possibly massaged the back side sof the spokes.
Now on the TTM not 100% sure. The spokes do not curve as much, and quite possibly would be OK.
