Can someone help me figure out my wheels offset?
Hey guys I did the math, but would like someone to double check. Also will they fit my TA?
They are Fikse FM5s
17x9.5
BS 7 3/8"
centerline is 5.1875
17x11
BS 8 3/8"
centerline is 5.9375
My results are
17x9.5 55.5625 or 56mm
17x11 61.9125 or 62mm
I am making sure the offset is correct before I mount the tires.
Thank you for any help.
Bob s.
They are Fikse FM5s
17x9.5
BS 7 3/8"
17x11
BS 8 3/8"
My results are
Bob s.
why do you need to know offset? It is a poor comparison to other manufactures specs. It is not standardized. Don't use it...It will get you close, but why bother.
Backspace is your best reference...by your numbers, the fronts are going to be "ok", the rears will tuck in a bit too much, you'll have issues with the inner fender and component interference.
according to the FAQ part of this forum:
what will fit on the rear:
11.0" wide rim ... +45 to +56 mm .... 305, 315, 335
what will fit on the front:
9.5" wide rim ..... +38 to +56 mm .... 255, 265, 275, 285
What are the wheels from?
Steve why do you feel offset is not a "standardized" way of specifying wheels . . .
Fronts calculate out to around 55.37 mm
Rears calculate out to around 61.72 mm
I am going to guess these are from a Corvette . . .
Fronts will fit like a stock SS or WS6 wheel, rears will need a spacer to mount.
The wheels could always be sent back to Fikse and re-hooped to fit and F-Car.
For your reference, our recommended backspacing for your application up front is 6.08", and out back is 7.58". Good luck!
Danny G.
Well what do yall recommend.
1. Can he mount these with 315 35 17 KD's on his T/A
2. Will he require a spacer and if so is there any safety concerns? I have just done some research and could not find any safety concerns.
I sold these wheels to 1badbird. I was going to put these on my firehawk and circumstances did not allow this to take place and pics are on this thread also. Thanks guys for all yall's help and Bob is a great guy!!!!
https://ls1tech.com/forums/southern-members/663345-north-carolina-richard-blankenship.html
Well hey there RIck!!! KDs are one of the widest 315s out there according to tirerack. Just concerned about the offset, and want to be sure before I mount the tires. We have experts here
BOb s.
BOb s.
Hey Danny! Good to see you're involved on the forums. To answer above...spacers can be used, be cautious of the amount that is used. You don't want to move your sheer line out too far on the studs.
Bead to bead measurement can vary. Use backspace, don't bother with conversions.
BOb s.
BOb s.
