What options do I have for a 28" tire for the drag strip?
Old 03-13-2007, 08:16 PM
WS6FirebirdTA00's Avatar
Default What options do I have for a 28" tire for the drag strip?
I am in need of a 28" tire for the drag strip. I want to see what you guys have to recommend for a tire as well as a rim. I would like to do this as inexpensive as possible (ie no bogarts) I also do not want to grind on my rear brakes. I dont mind running a stock rim (16 or 17) if I can get a tire for it. I have been looking and I have only found ET Street 28x11.5-16
Also, a 28" tall tire, will that cause and clearance issues in the rear for anything or no?
Thanks guys,
Mike
Old 03-13-2007, 08:50 PM
Moderator
JNorris's Avatar
Hoosier makes a 28.0x10.0x16 slick that you can run on a 8" wheel
M/T makes a 315/45R16 ET Street DR that is 27" and a 295/45R17 that is 27.5"
John
Old 03-14-2007, 06:09 AM
thanks
Old 03-14-2007, 06:21 PM
camaro98z28's Avatar
You are in the same boat as me. Stock wheels I can afford I just bought the ET Streets last night
Old 03-14-2007, 06:27 PM
Nice, where did you get them from and what size are they?
Old 03-15-2007, 07:44 AM
John
Does anyone sell the 295/17 yet or no?
Old 03-16-2007, 12:11 PM
Moderator
Black LS1 T/A's Avatar
I have run the 28" tall 11.5" ET Streets on the stock 16" wheel. Just a little massaging of the fender lip and trimming back the plastic a bit (not noticeable) works on a Firebird. I only had to trim the plastic piece when I discovered that scuff point at 145 MPH on the dyno. I'm glad I did that before taking it to the track.
I've heard a Camaro is a tighter fit, though.
Old 03-16-2007, 12:36 PM
I have been reading you cannot run a radial up front though, can you shed any more light on that one? I was all set on this and now I read that, so that kinda sucks lol
Old 03-17-2007, 09:31 AM
Moderator
JNorris's Avatar
I was under the impression that M/T "new" tires were released, but I could be wrong.
I run radial tires on the front and bias (non radial) tires on the rear with no problems. I also run radial/radial setup as well which is much more stable.
The sidewall on the bias tire has much more side-to-side movement than a radial tire.
Old 03-17-2007, 02:41 PM
ok, thanks for the info.
Old 03-20-2007, 12:26 PM
Moderator
I run radials up front, too. But, with "balloony-feeling" tires in the back like ET Streets, firm radials up front don't allow the car to track down the road very well (and especially at the track at 100+ MPH) . That is what was explained to me, and I believe it. The car feels a little out-of-control.
I'm considering either trying the M/T ET Street Radial or taking the fronts to bias ply.
Old 03-20-2007, 12:46 PM
yea I think I am going to stick with the MT radials, hopefully the new sizes come out soon
