what size tires fit?
what kind of drag radials wil fit on my car if i get 15x10 inch draglites, with out touching the fender wells, i do not want to cut anything but the calipers, can i use a 27.9 size tire, or do i need a 8 inch rim with 26's
The 325-50-15 BFG's will fit with some work . I am going to put the same combo on my 99 SS.I have heard you have to remove the bumpstops for the rear end . You will also need a 7.5 in. backspacing.Did you live in Asheboro at one time?
