Where to purchase STOCK chrome or stainless lugs and locks?
I found out the other day the lugs that are on my car can not be removed with the jack handle thing. So that means if I got a flat tire I would have been SOL.
I know I need 3/4" hex acorn bulge lugs but I can't find any to buy. The only place I have found them is at Gorilia's website but I can't order from them. Could someone point me in the right direction?
I've tried Ws6store.com but the lugs they have are the stock lugs with plastic chrome covers, but also says you can't use them on WS6 rims. Tried afterthoughtsauto and the same thing. Tried ebay, can't find the right size. Thunderracing has a bunch, but I can't find any with 3/4" hex. Do I need the 12mmx1.5?
wheels
I dont know if these will work for you but check them out. The lug wrench is pretty cool actually. At least for along side the road. When I had my bird that exact thing happened to me. I was fortunate with a passerby who happened to have a big set of vice grips. Although it scratched the rim and destroyed the lug nut I was able to get it loose.
http://www.westcoastcorvette.com/pc-...g-nut-pkg.aspx
http://www.westcoastcorvette.com/pc-...ut-wrench.aspx
These are the lugs that I actually use now. All 5 nuts are a lock its a pretty cool looking set up.
http://www.lgmotorsports.com/catalog...roducts_id=325
good luck
good luck
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
ws6store has exactly what you're looking for.
is this not it?
http://www.ws6project.com/user_stor/...02b9ee12a26db4
is this not it?
Originally Posted by Ralls
Your lugs must be on too tight then. Make sure they are 100 ft/lbs. I can take mine off with my 1/2 inch ratchet which is probably shorter than the jack handle.
is this not it?
is this not it?
good luck
good luck
it's kind of like i said, i either don't understand the question, or your not looking at what i am.
locks
lugs
they used to sell a package of 20 locking gorilla lugs. didn't see those on the site, may want to call and ask.
locks
lugs
locks
lugs
locks
lugs
