how much do skinnies help??
hey guys... im probably gonna get a pair of drag radials for this summer and mount them on my stock 16's... but i was thinking about getting some skinnies for the front... my question is how much do they help? has anyone raced with them and then with out them to see the difference if its only gonna take like a 10th off then its not worth it.... also do you guys drive the track with you skinnies on... i dont know how i would change them at the track... id have no where to put my other wheels if i did it that way... thanks guys
When I drive around with my Bogarts on, I can definetely feel the difference. Not so much that I'm faster, but I have very little spin and the weight distribution is improved a good bit. I can feel and see the front end lift up (not wheels up) when I hit WOT.
It does take a good bit of weight of the front and helps with weight distribution. I'm not for sure exactly how much those stock 16" steel rims weigh but I know a lot of guys say you can save as much as 40-60lbs. off the front with skinnies and tires as opposed to the stockers.
kool im probably gonna do it then... my stock 16's arent steel they are aluminum 5 spokes... they arent the lightest but they arent very heavy either....what is the proper size of skiinny wheels for the front and tires for the front on a 4th gen f-body... do i need spacers?...
Originally Posted by 99kamarokid
just outta curiousity, can u use your spare tire +1 for fronts?
yes you can run 5/16 spacers up front but you need to get longer studs or you can grind down your calipers which is the safer way to go and really isnt that big of a pain to do. if i didnt break my camera i would post up so pics of what the calipers look like grinded but do a search and you should be able to find pics
Originally Posted by Bow94z
What Lugs does everyone use on Draglites?
Using a 5/16 spacer and 3.25" studs
