What bfg drags for firehawk rims
What width are firehawk rims? is it 9 or 9.5? I forgot and am not in town.
I am thinking about bfg drag radials and they dont have the size tire i have now 275/40/17.
What size will fit my rims and work the best for all around driving?
BMW ///M Nerd
Originally Posted by pHEnomIC
What tires are you running bad ***? Obviously with an almost snapped driveshaft, you are hooking up alright.
The driveshaft damage actually happened after I broke my factory torque arm after powershifting 2nd gear. I was on 18" Michelin Pilot Sports at the time. Just goes to show how shitty the factory stamped steel parts are...
Originally Posted by BAD *** TA WS6
No, 275 is max for a 9" wheel. 285 KDs will be way to big for the 9" wheel.
The BFG DRs will fit perfectly in the 275/40/17 size. Not sure what he is talking about by them not looking "meaty"....
why would the 285 be to big, my friends camaro on the stock rims was running the 285 at all corners , my camaro & firehawk as well as a friends firehawk where running 315s on the back only
SO can we run a 285 on the normal rims or not?? Id like to get the widest possbile....does anyone on here have these on their stok 17in fiehawk rims or early ws6 wheels???
BMW ///M Nerd
315s need an 11" wheel, no questions about it. It's physically possible to mount them up... But that doesn't mean it's right. Tire failure can occur, and then you're going to be sorry.
The manufacture recommends a minimum width for all their tires. Don't be retarded...
Originally Posted by dailydriver
Since when did anyone make a 285/40 17 drag radial???
do you know how hard you would have to push those tires for them to fail, one, I worked for goodyear so i know all about what tire companies recommend and should be done, also the firehawk is running a 743rwhp car and sees lots of hard driviing time with no failure
