Probelms fitting 10-spokes on LT1?
So i got a hold of a set of ss ten spokes and i put them on my 95 Z and went down the road and noticed a little vibration in the back end so i go check the back rims and there not seated all the way to the rotor, so i pull the center caps and the rims were wedge on to the axle housing with about and eigth/ inch showing between the rotor and rim and you could see shavings. so i sandpapered it and a little silcone but still the same issue. should I grind on the rim or housing or what thought these things were a direct bolt up thanks for the help.
