Jus got c6 z06 rims..wont fit in rear??
I jus got them and put the fronts on no problem....18x9.5 all the way around...the rears dont sit flush like the front....Need help...Thanks Jason!!!
what is the bumpstop...i tried jackin it up differently but it still wont fit...The problem is the wheel jus wont fit flush against the rotor....i dont know what to do...
looking at your name I take it you have a 97 z28? If so i am pretty sure I have read on here that you need to grind down the rotor a little as they are a tad bigger then the ls1 rotors that the wheels are made for? I could be totally wrong hopefully others will chime in
No don't grind down the rotor. You need to grind the inside hub of the wheel. Don't worry, you will never notice from the outside. The rear hubs on the the LT1 cars are 1mm larger in diameter than the fronts. This problem was later corrected(I though 97, but I guess it's 98). This issue wasn't accounted for on most aftermarket wheels, and thus the wheels won't fit over our rear hubs. I had to buy a dremel tool from sears for the project. Just slowly and evenly grind the center hub out of the wheel. Take your time and make sure they fit right and flush when you are finished. The first time I used a grinding stone bit, but after I rotated my tires I found a metal cutting bit that did the job much faster for the second two wheels. This isn't an extremely common problem on LS1tech because most of the cars on here are..LS1's without this issue. It's well documented on cz28.com. I did this on all four of my 18x9.5 Chrome C6 wheels without any issues.
