What to do to make Z06 wheels fit F-Body?
Old 04-22-2007, 12:30 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
Default What to do to make Z06 wheels fit F-Body?
Do folks run just 4 fronts or what do they do?
Old 04-22-2007, 12:31 PM
02silvaZ's Avatar
you can buy the rims in the correct offset from most rim distributors
Old 04-23-2007, 07:49 AM
JGKadell's Avatar
OEM is much lighter
Old 04-23-2007, 10:54 AM
FRUSTRATED T/A's Avatar
im woundering the same question, as i may get a set of 18/10.5 rear wheels but dont know their ofset.
i believe they might be 58mm. Ive searched and most say a 1/4 spacer will do it, and bigger and a longer stude is needed.
Old 04-23-2007, 12:59 PM
SSilverSSurfer's Avatar
which ones you trying to run?
Old 04-23-2007, 01:02 PM
kbronSS's Avatar
i just ordered some from tomzwheels and i have no clue what offset they are. but i did order two 18x10.5 for the back with 295/35's. guess ill have to wait til they arrive to see if they fit.
Old 04-23-2007, 01:17 PM
LS1Tech Co-Founder
I'm wondering if stock 17/18 Z06 wheels bolt right on.
Old 04-23-2007, 01:43 PM
Xsta Z 28's Avatar
Fronts do. Rears will need about a 1/2" spacer, since I beleive they are 65 mm offset.
Old 04-23-2007, 01:46 PM
Customizing Director
MadIceV8's Avatar
Nevermind, Xsta answered, lol.
Old 04-23-2007, 07:07 PM
kbronSS's Avatar
these are the ones i ordered....says 58mm....will they fit?
https://host279.ipowerweb.com/~tomzw...9c200caa1d2442
Old 04-23-2007, 07:09 PM
2002/Black/SS's Avatar
i just odered mine and they fit, i dont even remember telling them it was for a camaro
Old 04-23-2007, 08:01 PM
BROKEN's Avatar
i have stock gunmetals 17/18 with bfg 295 and they bolt right on with a lil bfh not to much thoug
Old 04-23-2007, 08:19 PM
Rebob5's Avatar
I have 18x9.5 and 18x10.5 ZO6's on my car with 53mm offsets front and back and had to do no BFH'ing at all. I am running 295/35/18 KDW 2's out back and they fit fine. I bought the wheels with the intention of putting them on a Vette so the offsets are factory corvette I believe. This is from the website I bought them from.... "Wheels have correct offsets for 1997-2004 C5 or Z06 Corvettes and wheels accept tire pressure sensors like factory".
I have pics of the 53mm offsets if anybody needs to see them.
Old 04-23-2007, 09:33 PM
B02SS's Avatar
I'd like to see pics of the 53's
Old 04-23-2007, 10:32 PM
MadIceV8's Avatar
Yes those will fit.
Old 04-23-2007, 11:34 PM
kbronSS's Avatar
Originally Posted by MadIceV8
Yes those will fit.
quick question about your car.............WHAT COLOR IS IT!!??? where can i find the code, i believe it is the same color as my vert but i want to make sure.
Old 04-24-2007, 12:37 AM
tbird31's Avatar
my buddy put some stock Z06 wheels on his 95 Z...he cut the bump stops off though...i probably wouldn't have done that.
Old 04-24-2007, 08:26 AM
carado1984's Avatar
are we talking about c5 z06 wheels?????????
with bfh they fit with a 295/35 and without, a 1/4 in spacer.. however i did bfh and still use a 1/4 spacer so it looks lines up better with the fender.
Old 04-24-2007, 10:50 AM
Trunion King
bene's Avatar
I have 18s 9.5"/10.5" 53 MM offset C5 Z06 wheels. No BFHs on mine either. Pictures are in my FQuick garage.
Old 04-24-2007, 02:52 PM
sweetask1ng's Avatar
the max offset camaro's can fit I believe is 56, so 53 will be fine... Anything bigger than 56 you should probably get a spacer for. I'm putting 19's on the back of mine, anyone know if a 1/2in spacer is the right size?
Quick Reply: What to do to make Z06 wheels fit F-Body?
