Anyone use weld rodlites?
I called summit today to order a set of rodlites and them stop my order to get here double verified my application.
First the fronts comes only in 15x4 not 3.5
second the back one in 15x10 only comes with 5.5bs so i have to use 15x8 and i going to run MT drag 15x10x28.5
So what you guy think. Anyone had pics of the rodlite in a camaro?
Thanks so much for your help in advance.
I am sure it would look good, but it won't work with that backspacing. You will need 7.5" BS for a 15x10. Now if the 15x8s can be had with 5.5" BS, then that should work. I am not sure about the fronts.
