Pro Fronts
Old 05-22-2007, 03:16 PM
blueeyeddevil141's Avatar
Default Pro Fronts
I may be picking up a set of Pro Stars. What size/shaving/whatever needs to happen to get a set of skinnier Pro Stars to fit up front? I want a 15" rim, and whatever width will work best (probably a 6.5 or smaller).
Old 05-22-2007, 11:29 PM
bmealer's Avatar
If you don't want to shave the front calipers, you can go with a 3.5" wheel with a 5/16 spacer and 3.25" lug studs.
Old 05-23-2007, 06:09 AM
LS69TA's Avatar
3.5 is the max on a ProStar if you have a LS1 car. You can run the spacer and longer studs if you don't want to grind.
