2001 Trans Am w/ Zo6 rims rubbing help!!!
Old 05-24-2007, 01:43 PM
WS6Guy25's Avatar
Default 2001 Trans Am w/ Zo6 rims rubbing help!!!
I have 18x9.5 rims with toyo 285/35's in the back. I am rubbing really bad when I enter and exit the highway. I was wondering what size wheels everyone is running on their Trans Am. What do you think is the problem>?
Old 05-24-2007, 02:47 PM
LS69TA's Avatar
You might try an adj. PHR. to give you a little lateral clearance. Find out where they're rubbing first.
Old 05-24-2007, 02:51 PM
530transam's Avatar
i had oem zo6 rims on my 99 trans am with 295/18's and a 10mm spacer and they never rubbed. If its the factory z06 rims then they rub in the back against the bump stop almost and you need a small spacer to push them away from it. But if you go more than 10mm youll have to roll your fender. Thats what was happening in my case it may be the same for you plus the stance you get with the spacers is awesome. Got any pics?
Old 05-24-2007, 05:11 PM
WS6Guy25's Avatar
I have pics, but I have to host them somehow. I have a panhard bar on there, but its not adjustable do you think this could be the problem
Old 05-24-2007, 05:28 PM
E-WAY's Avatar
Photo bucket them!
Old 05-24-2007, 11:58 PM
wabmorgan's Avatar
Is your car lowered????
I only ask.... becasue I am running same size tires on C6 18*9.5. I don't have any rubbing issues.
If your car isn't lowered.... I would think your offset on your Z06 rims are differant than mine.
Old 05-25-2007, 11:26 AM
FadedSS's Avatar
first find out where its rubbing then trouble shoot. i run 295's in rear with no rub at all...
