problem with staggered wheel sets? - LS1TECH
Thread Tools Search this Thread
Old 05-26-2007, 01:56 AM   #1
nine-eight's Avatar
Default problem with staggered wheel sets?
Hello, ive tried the search function, and have found some posts saying one way and some another.... im wondering if i can get a set of oem zo6 wheels for the weight reduction, and not have the different sized rims (17 front 18" rear) wreak havoc on my traction control and my abs system...is this true? and if so is there any way around it? i really want the oems for the weight, since the reproduction ones seem to weigh so much. anyone have any insight for me?
nine-eight is offline   Reply With Quote
Old 05-26-2007, 08:12 AM   #2
You just need to make sure that you get the right size tires so that the overall height of the tire is the same as stock. So your car will never even know that the wheels were changed. Not sure what size wheels your trying to get. but im assuming 17x9.5/18x10.5? If you get 275/40/17s for the front and 295/35/18s for the rear. You'll be good.
Donohue96M6Z28 is offline   Reply With Quote
Old 05-26-2007, 10:01 AM   #3
michaelg589's Avatar
please dont do staggered diameters youre going to have a larger profile tire up front.
michaelg589 is offline   Reply With Quote
Old 05-26-2007, 01:00 PM   #4
I agree ^^^
Staggered setups are for vettes, they have diff size wheel wells so it fills in better. I'd never put a staggered set up on my z.
Old 05-26-2007, 10:55 PM   #5
exactly.^^^^
Vettes have smaller wheel wells up front, so they pretty much HAVE to have different diameter wheels to look good. f-body wheel wells are exactly the same size if you measure at the very bottom horizontally, and vertically I think the front wheel well might actually be bigger. so it makes the staggered"ness" look even worse. do staggered widths, not diamteres. firebirds in particular need a bigger tire in back.
Old 05-27-2007, 12:24 AM   #6
02Z28LS1's Avatar
you could probably just get the change in tire sizes tuned in the computer so it won't freak out
02Z28LS1 is offline   Reply With Quote
Tags
02, changing, control, g8, gt, options, rim, sets, sizes, staggered, tire, traction, trans, wheel, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
