wheel studs???
wheel studs???
OK, i broke a rear wheel stud on the t/a... I have the chrome 16x8 5 star wheels with the solid chrome lugnuts... I want to change to ARP studs, what size do i need and do they make a deeper closed in lugnut to run longer wheel studs??? thanks ppl
why do you want to upgrade to the longer wheel studs? You have stock wheels with out spacers etc. You can just change that one stud with out even taking off the caliper. makes more sense then doing all the work to change them all to longer studs for no reason.
well, i figured if i was gonna change one, might as well do all of them, and im possibly getting some draglites from a friend that used longer studs and small spacers to fit on the car, but i want to change the factory wheels out for some black Z06 wheels staggered 17x9-17x11 and i want to make sure its strong enough.... and what size and length do i need to replace them??
Originally Posted by 69TA
I went with
ARP #100-7708
12MMx1.50"
ARP #100-7708
12MMx1.50"
you saw how easy i changed all mine. Took longer to jack up the car then to change the studs. And dont let people tell you to remove the axels, that crap is a joke. If your still going to buy the welds from me then you will need longer studs. summit has them for like $30 for everything or something like that. Its not a DD so no need to waste money buying one form the auto parts store when you will just be taking it out in a few days/week
Not trying to highjack the thread, just had a quick question I thought someone in here might know... what is the length of the stock studs versus the ARP 7708's stated above? Are these the same length or are the ARP's longer?? I just bought a set only to realize the 7713's are 3/4" longer than the 7708's (oops).
