Biggist Tire Fit On A 16x8 Rim
Old 05-29-2007, 02:15 AM
speedylexus2006's Avatar
Default Biggist Tire Fit On A 16x8 Rim
I Want The Best Street Tire That Can Fit My 16x8 Rear Rims
I'd Like To Have Some 315 Or ? Whats The Best Street Tire Otherthan Cheater Slicks Something That Hooks Pretty Good For A Street Tire
Thanks
Old 05-29-2007, 02:38 AM
Jeff M's Avatar
255 or bust
Old 05-29-2007, 02:40 AM
MASS seller approved
smok'nZ's Avatar
M/T 255/50/16 its a radial tho nittos are ok if your an auto but if your a 6 speed you need M/T's
Old 05-29-2007, 02:48 AM
I Have The M/t 255 And There Gone Already Atleast The Left Side I Guess Theres More Torque On The Left Rear I Have A A4 96ta The Right Tire Is Fine But Im A Crazy Fast Driver And Burn All The Time Around Corners And Lights I Love It And Live For It But The Tires Are $255 I Paid And Now Need Another Pair Already Im Only At About 1800 Miles And The Left Tire Is Already A Full Slick The Right One Is Good Still Tread Left So I Was Thinking Of Buying 1 And Burn'em Both Till There Gone Or Buy Some Badass Street Tires Which I Would Like To Do?????so Whats The Biggist Tire I Can Fit On My 16x8 Rims??????????????????????????????????????????????
Old 05-29-2007, 03:36 AM
WolfgangX's Avatar
315's are 12.4" wide, no one in their right mind would put that on an 8" wheel, 245 or 255s. You might want to look into getting some used SS wheels, those can fit 275s and are pretty cheap.
Old 05-29-2007, 09:42 AM
Jeff M's Avatar
Like I said above "255".
Old 05-29-2007, 09:49 AM
Stang's Bane's Avatar
The best thing to do is to learn how to capitalize correctly..
Old 05-29-2007, 10:03 AM
Ericbigmac83's Avatar
255 is the biggest you can put on safely
The m/t is a great track tire, but as youve seen, it will wear out quickly with those driving habits on the street. Go with the Nittos if you want more of a street drag radial.
Old 05-29-2007, 01:50 PM
michaelg589's Avatar
I'm buying 255-50-16 MT et drag raidals soon for my 16x8s. thats the biggest you should really go to be safe. 315 should not ever go on anything less than 10.5"
Old 05-29-2007, 02:03 PM
1slow98Z28's Avatar
i have the nitto 555r 245-50-16 and when i want to race i let them down to15-20 lbs and they work great and then normally run them aroun 23-25 psi and love them n will be buying them again when i have to replace tehm
