rpm launch on m/t drag radial
Old 06-06-2007, 10:47 PM
white mongoose's Avatar
Default rpm launch on m/t drag radial
i just curious how hard have u guys left with this kind of tires especially m6 im planning on buying some 275/50/15 m/t but wana go 2 the track but dont have a clue how good they will hook my car 98 ss cam, boltons,9,lca,t/a u guys thing these tires will hook good dumping the clutch at 55xx or 6xxx what do u guys think
Old 06-06-2007, 11:35 PM
anyone?
Old 06-07-2007, 12:07 AM
gangbang malloy's Avatar
depends r u gonna use VHT trackbite or not?
Old 06-07-2007, 12:08 AM
02 Camaro SS's Avatar
I've launched them at 5000 rpm and popped a little wheelie with the 255/50/16s. The trick is you can't just dump the clutch or you will just spin all day. Instead you have to learn to let the clutch out VERY quickly.
Old 06-07-2007, 03:02 PM
99kamarokid's Avatar
whats vht trackbite???
Old 06-07-2007, 04:38 PM
LSGunZ28's Avatar
I dump clutch at 5500 and still bog.
Old 06-07-2007, 05:04 PM
tham lsgun u still bog at 5500 where do u set ur psi in ur tires that u still bog
Old 06-07-2007, 05:06 PM
what do u mean by letting the clutch out very quickly isnt it the same thing as dumping it any vids of ur 1/4 good times whats ur 60ft
Old 06-07-2007, 10:26 PM
its a liquid compound that goes on tires and after a nice burnout makes the rubber on the tires like glue, it sounds like duct tape being pulled off when the tires roll forward. works miracles and makes u hook so damn well. that combined with a drag radial makes for a slingshot launch.
Old 06-08-2007, 11:19 AM
carado1984's Avatar
some tracks prepped well use it you can feel it when your walking on it.
Old 06-08-2007, 02:26 PM
yup makes tires and the rack really gummy
Old 06-08-2007, 02:27 PM
just sucks to remove from it from ur car. if anyone has any good ideas on how to take vht off the paint without damaging the paint please let me know
Old 06-09-2007, 04:43 PM
andy670ho's Avatar
yes, spray pam on your car before you use the vht, spray it everywhere you think the vht will hit, then it just wipes off.
