Anyone running 275/35 on 10.5in wheel
Old 06-08-2007, 11:36 PM
xBROKEx's Avatar
Default Anyone running 275/35 on 10.5in wheel
anyone?
Old 06-09-2007, 01:10 AM
TooSlow02's Avatar
Originally Posted by xBROKEx
anyone?
I've done it.
Old 06-15-2007, 03:34 PM
xBROKEx's Avatar
well i went ahead and had them mounted on the car and it looked retarded, the tire was way to small. it did fit but looked way to stretched, luckily the guys at my local Discount Tire were cool about it and let me order some 295/35/18 KDW's.
Old 06-16-2007, 01:04 AM
SS LS1's Avatar
I wouldn't recommend it as the tire will look way too narrow. I run 295's on a 10.5" wide wheels and the side wall is vertical, the 275's would need to be stretched quite a bit.
my 295's...........
Old 06-16-2007, 06:44 AM
xBROKEx's Avatar
yeah when i saw the 275's on the back i was like yeah thats not gonna work, they were way to stretched
Old 06-18-2007, 05:06 PM
01 ws6 uk's Avatar
my 295's...........
What size front wheel/tyre you running with ?
Old 06-18-2007, 06:26 PM
SS LS1's Avatar
Front = 275/35/18 on a 9.5" wheel
Old 06-18-2007, 10:14 PM
01 ws6 uk's Avatar
I'm looking to change the 17x9's on my T/A as the tyres (275/40/17) are virtually impossible to get hold of in the UK, and if you can, come in between $400-500 each !!!!! I'm looking to go to an 18" rim as there are many more and cheaper tyre options but here in the UK am getting loads of conflicting information about what will and what won't fit !
Initially I was looking just to change the wheel diameter and keeping the same width tyre and lowering the profile to a 275/35/18 but like the idea of making the rears a bit wider, such as 295 (i think the T/A has more room in the arch than the camaro ?).
Did you need to modify anything for your set-up ? And what off-set were they ?
Thanks
Quick Reply: Anyone running 275/35 on 10.5in wheel
