Info For Lowered Camaros
My 01 is running on sportlines and has a advertised 1.8" drop, but I think its more like 2". I really would like to get 18" on all four corners. Any info on max width i can run on back and offsets for all four corners would be great.
Is this what I am looking for on the rears?
18"x9.5" +50 to +56 mm 275/35R18 or 285/35R18.
18"x10.5" +50 to +53 mm. Higher than 53 mm will require the BFH mod. 285/35R18s thru 315/30R18. Over 295 may require rolling the fenderlip and will need the BFH. +58 mm is the typical available offset for the Z06 replica, which will require a little BFH and/or a small spacer. Thanks!
