C6 Wheels on lowered T/A
Old 06-18-2007, 10:57 AM
colby72olds's Avatar
Default C6 Wheels on lowered T/A
i purchased some 18*9.5/10.5 C6 wheels and my t/a is lowered about 1.5 inches all around...will there be any issues i should be concerned about? any help would be appreciated
Old 06-18-2007, 12:42 PM
02trns_am's Avatar
the fronts will be fine for sure. What size tires are you putting on the back?
Old 06-18-2007, 12:58 PM
TXws6's Avatar
should be fine. Maybe some BFH depending on the size tire you plan on running in the rear.
Old 06-18-2007, 01:36 PM
im not sure what size the tires are..what is BFH?
Old 06-18-2007, 01:39 PM
what size tires will fit in the rear? tires are included with the wheels, i just dont remember
Old 06-18-2007, 01:51 PM
02trns_am's Avatar
BFH = Big F***ing Hammer mod. You beat the inner fender wells in some so the tires won't rub. If the tires are like 315's or something similar you will most likely have to do this.
Old 06-18-2007, 02:00 PM
oh ok, thanks alot
Old 06-19-2007, 01:14 AM
michaelg589's Avatar
if the tires were included, they may have given you 315-30s just to try and keep the overall diameters equal. You will definately need to do a little BFH for them to fit. I am also lowered 1.5" with the exact same wheels, I have a 295-35 in the back with 5/16" spacers, and pretty much no rubbing.
Quick Reply: C6 Wheels on lowered T/A
