torque on lug nuts
I always torqued mine to 70 ft-lbs in a star pattern, then went back over them at 100. Eases the torque onto the hub, keeps the brake rotor from warping. Never had a problem with rotors after starting this system.
Byrdman
Byrdman
Byrdman
Byrdman
this is the correct way of doing it LUg 1,3,5,2,4
Originally Posted by TheLS1Kid
I torque mine to 80 ft-lbs.
I guess everyones a little different.
Byrdman
Lug nut torque is totally dependent on the size of the stud you have. Bigger studs/Lugs require more torque. The proper torque for a 12mm stud (which is I think, stock on these cars. And I'm too lazy to go out to the garage to look) is 70-80 ft.lbs. Aluminum wheels should always have the lugs retorqued several times till the torque stabilizes.
I bought a 100 ftlb torque stick. I think it works by magic.
http://www.torquestick.com/
With all the $$$ you spend on the car, don't cheap out. Do the wheels right and save yourself time and money in the long run.
Byrdman
