17x11 & 315 nittos!!
Depends on how low you are and whether or not the rearend is centered. Some cars rub more than others, too, as the body tolerances aren't always super tight. That is the correct offset, and I've also heard that Nittos run narrow compared to other 315/35/17 tires.
-Mike
-Mike
One word of advice: You'll have to jack up the rearend by the differential housing. Many people think their 315's don't fit because they hit the bumpstops when they're trying to bolt them on, but it's because the axle is hanging (i.e. jackstands under the frame rails). If you jack up by the axle, you won't have that problem.
-Mike
Dont have them myself....only have 245/50/16 nittos But from what I hear all over the board they deffinately run narrow. So with an adjustable PHR and probably minimal big fuc**** hammering, you will be fine!
You beat me to this post, I have the same setup but not installed yet. I feel like the nittos definitely run narrow for a 315. I am mounting them on the wheels this weekend and I'll let you know how it goes. I have the stock slp suspension, but I definitely for see beating the inner fender well. Anyone run this setup with strano springs b/c I have plans on lowering the car in the spring. If so what did you have to do to make it fit?
definitely let me know how it goes. now im hearing i would need a panhard rod? but i heard i wouldnt need the panhard unless im lowered?
basically all the adjustable panhard rod does is properly center the rear. The Nitto's do run very narrow. They were barely wider than the 285/40/17 BFG KDW tires I had before.
I let one of the wheels down and noticed the lip of the wheel hit and not so much the sidewall.
