weld draglite 15x10
Old 02-04-2008, 09:42 AM
tattooed4lyfe's Avatar
Question weld draglite 15x10
do i have to run longer wheel studs on the rear or can i use the stockers with diff. lug nuts, i dont race at all, maybe in the future.
Old 02-04-2008, 10:19 AM
i could also use a lil help with rear tire size....
Old 02-04-2008, 10:37 AM
black01_WS6's Avatar
if you don't race whay would you get these tires?
The rims are not DOT approved for street use.
Old 02-04-2008, 10:41 AM
SJM Manufacturing Inc's Avatar
Yes you need 3.25" long studs with spacers and grinding of the calipers. Shorter studs threading will not protude deep enough into the hex portion of the lug-nut.
Old 02-04-2008, 10:48 AM
i dont race because im not ready yet, tryin to get to that point.
Old 02-04-2008, 12:41 PM
jjordan's Avatar
Weld Draglites use a shank style lug nut that goes down inside the wheel. You will NOT need to change studs for street use, just make sure you have the correct shank style lug nut. Now when you start to race, an open end lug nut will let the tech inspector at your track verify that you have full engagment of the lug nut, without removing it. At that point you may need longer studs. The proper lug nuts for the Weld Draglites have a 1.310" long shank with a .687" diameter.
Old 02-04-2008, 03:15 PM
mrr23's Avatar
i still use stock studs with my weld 15 x 10 drag lites. 7.5" backspacing. 275/50-15 nitto DRs. no spacers. just alot of grinding to get to clear. i drive everyday on them.
bottom of page shows the grind work on the calipers and wheels mounted on.
http://stealthram.com/wheels.htm
what SJM says holds true, to pass tech at the track. the studs must be at least flush with the outer portion of the lug.
Old 02-04-2008, 03:35 PM
thanks alot guys....helped out alot
