will TTm 10.5 fit up front? hurry in???
Old 02-29-2008, 03:46 PM
LS1>Imports's Avatar
Default will TTm 10.5 fit up front? hurry in???
will they fit up front with 275 on them,
im about to order these real soon so please give me some info?
also if anyone has pics of TTm's on a camaro please post them up?
thanks
Old 02-29-2008, 03:51 PM
unSStoppable's Avatar
you can make 10.5s fit no problem up front with the right offset. I would go with a wider tire tho, 295 would be better IMO.
Old 02-29-2008, 03:52 PM
pozesd99''s Avatar
what are the offsets??
Old 02-29-2008, 04:04 PM
the offset is a 44, with a 7.XX backspacing, i think
Old 03-01-2008, 01:02 AM
come on someone has had to try this before,
and someone gots to have pics of TTm's on a camaro
Old 03-01-2008, 06:55 PM
carado1984's Avatar
Yes they will fit with a 275. Yes you will be stretching the tire inward. No i dont recommend it. No you cant get a 295 in a 17. Yes it will look stupid if you put a 315 in the rear and 275 on the front on the same size wheel.
If i was you i would run the 17x9 front and 17x10.5 rear with a 275/40 front and 315/35 rear. Look.
Old 03-01-2008, 06:58 PM
carado1984's Avatar
btw. i just remembered. Member BatmobileSS has my wheels but on a black SS so PM him maybe he has more pics.
Old 03-02-2008, 06:11 AM
well to late, 10.5 are alreay ordered, i like the look of the deep lip on the 10.5's, and im putting 285s up front, i think it'll look pretty saweet, you dont see to many people with 10.5's all around
Old 03-02-2008, 09:02 AM
LT194CamaroZ's Avatar
theres a guy on here with a SS running 315's on all 4 corners
Old 03-04-2008, 02:21 AM
i know it can be done, jus hope thier is no major modding to get it done
Old 03-04-2008, 09:04 PM
carado1984's Avatar
what size tires did you go with? the wheels themselves will fit fine, the tires are the determining factor.
Old 03-16-2008, 11:43 AM
groundpoundinlt1's Avatar
did you ever get these installed...im thinking of doing the same thing, just want to see how it looks and if theres any issues with fitment
Old 08-11-2008, 09:46 AM
00Camary's Avatar
How did the 10.5's work in the front for you? Any problems? Were the wheels the normal offset?
Old 08-11-2008, 06:33 PM
Bald54's Avatar
Not the best picture in the world. It's definately an aggresive fitment.
Pros: big lip, deep dish look on the front. Direct bolt on fit with no modifications needed, at least on a non lowered car.
Cons: The 275 looks a little narrow on the wheel, The flange sticks out a little from the tire. A couple mm's more positive offset would be perfect, but then you might have some issues on the inside.
I know, the car needs to be lowered.
Old 08-12-2008, 06:27 AM
00Camary's Avatar
So if i try a 56mm wheel i wont or will be able to get it to work? I got your PM about grinding the nub and the spacer. If i do that are you saying that i will be okay or will it just simply not work? I appreciate you giving me your advise on this issue. Thanks a whole lot
