Rear Weld Prostar With Spacer on 95z
Old 02-29-2008, 10:00 PM
cam2z's Avatar
Default Rear Weld Prostar With Spacer on 95z
Hi Guys i just got some 15x8 weld prostars for the rear, they have 5.5 backspacing my question is can i just run a 5/16 spacer in the rear like how you can on the fronts or will there be some sort of problem i will be also using the stock studs aswell. I dont care about passing tech at he track cause it is primaray use is on the street.Oh and one more thing i heard you cant use the center caps in the rear wheels is that true, my car is a 95z. thanks
Old 02-29-2008, 10:41 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
You are playing with fire using a spacer and stock studs on the back
Old 02-29-2008, 10:42 PM
cam2z's Avatar
But can it be done.
Old 02-29-2008, 10:46 PM
97badass's Avatar
im sure it can be done, if having the wheels is worth more to you than living!
Old 02-29-2008, 11:17 PM
Z28/2002's Avatar
Yes it can be done
Old 03-01-2008, 01:19 AM
sixvi6-camaro's Avatar
Yes it can be done and with stock studs and spacers you will have only a few threads of stud left to bolt the lugs to, so it will be very dangerous!
