weld magum 2.0's bolted up!
pics do not do justice. if the car had a chute on the back it would look like a 10.5 car. it sits way lower than the pics show.
saved 46 pounds from centerline telstars with MT radials and a full size front tire.
15x3.5 front 28" sportsman tire
15x8.25 rear 28" hoosier DR
LS1TECH Sponsor
I think you just made up my mind on what I am going to get....those look awesome!!
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
What's the backspacing on the wheels. Is there any rubbing front/ back?
Is the suspension stock height? I have an 85 Camaro that is currently lowered that I am putting back to stock height and was going with the same size rears so I just wanted to make sure they would fit.Thanks
the rears are 15x8.25 with a 5" backspacing. the way the wheel is made, it measures 5 3/8" from the inside of the lip.
the tire is a 275/60/15. its 28" and the hoosiers have a pretty wide section width of 11.5. i had already cleared my inner fender in front of the LCA in the wheelwell, so i have no issues.
actually have about a 1/4 to spare. i could do some more beating if i needed to.
car is down 1" in the front. the rear is a stock spring, minus the rubber isolators at the top, which take out about 3/4 inch.
the fronts are 1.75" backspacing. its tucked in pretty good. i wouldnt recommend the 2.25. it would fit, but look goofy, imo.
