bmw wheels
Old 03-14-2008, 11:15 AM
maxgee's Avatar
Default bmw wheels
Anyone have wheels studs break using bmw wheels?
I have heard this, but cannot confirm.
Old 03-14-2008, 03:11 PM
jjordan's Avatar
Yea it can happen if you are not real careful. Had a set of BMW wheels on my LT1. The BMW bolt circle is slightly different than the Chevy. It is so close that they will work but you have to watch the lug nuts, if they get slightly loose they put a tremendous strain on the studs because as they tighten up they bind up the studs slightly. Not a problem as long as the nuts are tight.
Old 03-14-2008, 04:00 PM
maxgee's Avatar
thanks!
Old 03-16-2008, 11:35 PM
69TA's Avatar
stock GM studs are garbage so I would be careful with them BMW wheels
