Question about rims
Question about rims
I had my stock 16in rim bead sealed recently. I put brand new Pilot Sport A/S tires on it. One of the tires was leaking air so I took it back to where I purchased the tires and they told me the tire didn't seal right, so they rebead sealed the tire. Well fast forward a week later to today and the tire went down from 35psi to 20psi. I am going to take it back again. My question is how many times can they bead seal a rim? At this point would it be better to purchase a reconditioned rim? I don't have the money to buy a whole new set of rims right now so that isn't an option. I really don't want to buy another rim but I am frustrated as my old set of tires were pierced by part of the rim and kept leaking air and they couldn't plug the tire. Seems like the last 2 months all I keep doing it putting air in the tires.
Is the rim damaged around the bead? If so then it will be hard to get a good seal. Also it is pretty much an accident waiting to happen and I would recommend replacing the wheel. If the rim is fine and the tire is just not seating properly they need to check the bead ring on the tire itself.
Thanks guys you made up my mind. I am going to have another rim put on today. I could feel the rearend wiggle from the 2 different tire pressures. Car's never been wrecked (knock on wood) and I only have 7 payments left to make on it before its year round daily driver duties are retired.
