DIY Black Wheels, what paint? tips/suggestions
Rims: 2006 Silver (NOT polished/chrome) C6 18/19 Rims (OEM)
I want them gloss black, but I do not want to pay a shop to do it.
What paint will hold up the best? I wash my car alot, also I need to take into consideration that the rims may get hot in the summer + driving/braking.
What prep should I take? Just aim and spray? Fine grit sandpaper + wetsand?
Thanks
Thanks
I did mine. Sorry no pics. I cleaned them really good, then tapped off the lip there I wanted to keep it silver. Sanded with 220 lighly to get a nice surface then hit the hard to get to areas with a scotchbrite. I used Rustoleum. Several light coats. I painted on a warm day outside so the light coats dried pretty quick. I did the inside of the wheel first.
Turned out really nice, noone believed i used a rattle can.
Josh
Josh
Josh
Josh
Good deal, i will look forward to the writeup
I emailed GMMG a bit ago about painting my wheels a certain color. They gave me thew color code and suggested I use "Etching Primer" before the paint. I called a local shop to see if they had any and the man I spoke to informed me that etching primer is old school, and you can just use epoxy. I'm not sure if this helps at all, but maybe you can research it a bit and find out what's what.
https://ls1tech.com/forums/appearance-detailing/875032-painting-my-10spokes-pics.html
I pretty much did the same as the above thread. I painted mine about 2.5 years ago now.. they are on their 3 set of tires in that time and have over 20K on them. no prblems with chipping, peeling or anything.
Cool, Ill do a write up for sure, and Ill make it a good one. Keep the ideas coming, Ive been researching and asking around for tips/pointers/ideas. Gimmie a week or two and Ill have it done.
just prep them very well, maybe even use an adhesive promoter if necessary, the paint section has a couple write ups that might be a little more helpful
