c6 19 backspacing
c6 19 backspacing
I found these on ebay and I know that the add says they will fix a 1999 fbody but what will need to be done. also what size tire could I fix on the back. I have done the bfh cause I had 18 with 315 on the back a year ago. Thanks any info would be great.
http://cgi.ebay.com/ebaymotors/19-18...spagenameZWDVW
theyll fit if you already have some BFH done. it says the 19x10s have a +68mm offset. my 18x10.5s have a +58mm offset the wheel is 1/2" wider but has 10mm less offset. I, however am running a spacer, which puts my wheel at about +50mm. The 19s should fit, worst case scenario would be you need a small spacer.
Thanks for the help. I did get the wheels anyone know what size tires i should look at. i was looking at a 295/35/19 for the back and not a clue about the front.
BFGoodrich g-Force T/A KDW-2
19x10 rear wheel with 285/35 tire
So you want my combo huh?
Rear needs 1/2" spacer with longer studs, BFH
Front is perfect
Rear Tire 285/35/R19
Front Tire 275/40/R18
Be very carefull about the tire size as it does not take muck to throw off the ABS and TC.
Front is perfect
I ran a 275/35/19 KDW on the rears and a 255/45/18 on the front. In the rear well i had to hammer in the the well just slightly because i was on Eibach Sportline Lowering springs. But with longer knurls and a spacer it shouldnt be a problem.
-Chris
*Note: Discount Tire screwed up my order so the front wheel profile was taller than i wanted. They told me the could get me the tires but they were 8 months backorder at the time.
-Chris
thanks guys for all the help.I think I will go with the 1/2 inch spacer in the back and should do me just fine I have use the bfh cause I had 315/18 on the car 2 years ago.
