Weld wheel ?
Old 04-06-2008, 08:09 PM
*98TransAm*'s Avatar
Default Weld wheel ?
i have been searching for about an hour now and havent really come across my retarded question. i was thinking of running a 15x8 with a 275/60/15 MT Drag radial in the rear and leaving the stock 17" ws6 wheels in the front just for the dragstrip, will this work??? also i know i will need to grind the calipers but the tires will fit right, i believe my car is lowered a few inches.
thanks for any help (i know im a f&^king retard)
Old 04-06-2008, 08:15 PM
im2fast4u98z28's Avatar
you shouldn't have any problems except the calipers
Old 04-06-2008, 08:19 PM
BOLO's Avatar
Yes, you will need to grind the calipers. And yes, those tires will fit. I run 15x10 7.5 bs w/MT 325/50-did alot of BFH, but worth it. Check out video below in my sig.
Old 04-06-2008, 08:26 PM
thanks guys
Bolo, so basically you just take like a rubber mallet and beat the **** out of the fender for the tire to fit? o yeah nice video.
Old 04-06-2008, 08:55 PM
Donohue96M6Z28's Avatar
Originally Posted by *98TransAm*
thanks guys
no.. for the BFH you get a rubber mallot and bash in the areas in the INNER FENDER WELL where the tire rubs. If it rubs the fender. Get a fender roller and roll the fenders right(use a heat gun etc). Or you will have ripples in your fender.
Old 04-06-2008, 09:27 PM
'Trust''s Avatar
It would take forever to beat the inner fender-wells with a rubber mallet, I always use a good solid mallet and recoat it with rubberized coating.
Old 04-06-2008, 11:22 PM
thanks for the replies, one more question on a 15x10 rim everyone is saying they run a MT 275/50/15 radial, yet summit says the maximum width of rim you can have on a 275/50/15 is 9.5???!?!?
Old 04-06-2008, 11:41 PM
mrr23's Avatar
here's mine 15 x 10 with MT 275/50-15.
Old 04-07-2008, 07:07 AM
BOLO's Avatar
thanks guys
No sir, you need more than a rubber mallet for the job. Something HEAVY. And don't be afraid, you're not going to hurt anything.
You can run 275/60's, check out Larry @ Speed Inc.(LT1 Project car) he's running them.
