New tires needed
A 285/35/18 or a 295/35/18 would work on the car but you may be limited by the wdth of your wheels. The 285/35/18 will work on either the 9.5 or 10.5 wide wheels. The 295 is not recomended on the 9.5 wheel.
thanks for the help. I plan on lowering with Strano springs and new shocks when they're back in stock. I messed up going with 265/35 and should of bought a little thicker tire? I figure after I dropped the gap on the top by lowering it then I would need to fill in the gap from front to back with a bigger tire?
