Tire Sizing Question (275/40/17)
Old 04-20-2008, 02:43 PM
shepuz2's Avatar
Default Tire Sizing Question (275/40/17)
When I bought this 2000 Z28 last year it had 255/45/17's all around and I replced them a few months ago with 275/40/17's all around because I've seen it a few places where those were an upgrade option with the 17" rims.
I've been having an intermittent chirping that I thought was the brakes, but now I'm wondering if it could be the tires rubbing since I went to the 275/40/17's - and it seemed to have started a few days after that. Brake pads and rotors are all 6 months old and have been lubed, sprayed, etc.
Thanks.
Old 04-20-2008, 02:49 PM
blownws6_nc's Avatar
I would'nt think 275's is the problem, being there's a lot of guys Lowered 2", I think it is another problem, not the tires.
Old 04-20-2008, 03:07 PM
95GreenZ28's Avatar
I am lowered 2" and have 315s w no problems
Old 04-20-2008, 04:53 PM
tylerdj's Avatar
No reason they should be rubbing with those on your stock wheels.
Old 04-21-2008, 08:36 AM
Xsta Z 28's Avatar
275/40ZR17 is the stock SS and WS6 tire size on the 17" x 9" wheels. . . .
Old 04-21-2008, 08:51 AM
SIC LSX's Avatar
you you should have any rubbing at all! I used to run 275s front 285's rear on my old SS 35th le wheels 17x9
Old 04-21-2008, 08:53 AM
SIC LSX's Avatar
what wheels do you have are they after market?? they may have wrong back spacing. You dont see many f-bodys running 255/45/17's
Old 04-21-2008, 10:03 AM
BadGTho's Avatar
your issue has nothing to do with tires.
what type of pads/rotors are you running? are the caliper slides greased?
BadGTho's Avatar
that's because it's a wierd size.. it's not at all common.
Old 04-21-2008, 11:38 AM
staringback05's Avatar
275s can rub on the front...but slightly...ill have to post pics...but i have two nice shiny spots on the front wheel well...but its not going to make them chirp, thats something else
Old 04-21-2008, 02:49 PM
leadfoot4's Avatar
Thanks.
Since the 275s are a little wider, and your noise seems to have started after you installed them, this might be part of your problem. When does this noise appear? When turning or going over dips in the road? Is your car lowered? if so, does it have an adjustable panhard bar, so you can center the rear axle? Are the wheels stock or aftermarket? If aftermarket, the offset might not be quite right.
If it happens over dips in the road while going straight, it just might be a tire rub, due to the rear tire rubbing the outer fender. If it happens while turning, it could be the front tire rubbing the inner fenders, at the leading edge. Any evidence of rubbing on the sidwalls of any of the tires?
