couple questions,also weld lug nut part # request..
draglites are going on soon,i'll be using 12mm x 1.5,3.25" studs for the rears 15x10.
i'll be ordering 2 summit knock off draglites for the front, which should be 15x4, 1.75 backspacing right? along with having the summit wheels up front, i can get away with leaving the stock studs,right?
can some one also give me a part number for the right lugnuts to use from weld racing?
thanks for any help.
For the Weld Draglite: 12mm Open end p/n 601-1422, closed end p/n 601-1412. Pretty sure these wil not work with the Summit wheels. Torque 12mm studs to 70-80 ft lbs and recheck lug torque every 25 miles till it stabilizes.
