will a bolt pattern of 5 x 130mm work on a 1993 trans am?
I have some 5x130mm bolt pattern wheels and want to know if they will work on my 93 trans am, if not what can i do to make them fit?
re
i already checked out the stickies,but cannot get an answer,all i found was that the pattern is 5x 120mm and it doesnt say what can work,please just answer the question.
What part of 130mm > 120.6mm don't you get? THEY WON'T FIT!!! You could get an adapter that's gonna cost $200+ for a set of four which will throw off your offset so they probably wouldn't fit anyways.
So what do you mean you cant find an answer? Obviously anything outside of 5 x 120.65 doesn't work, so what kind of answer are you looking for? Doesn't get any more clear than that.
F-bodies = 5 x 4.75" or 5 x 120.65 mm
GTO = 5 x 120 mm
DO NOT PUT THE 5x120 WHEELS aka GTO wheels on your car. My car had them when I bought it and I spent a day after ripping the wheels off replacing the studs, and let me tell you it wasnt a fun job
