What backspace Prostars will fit the front, with minimal grinding??
I purchased a set of Greg Weld Wheels 15x5 with 3.5 bksp for the front. They sit right on the caliper. Will a Weld Prostar work on the front , without spacers?? If so what size should I order?? Thanks
No Prostar or any 15" drag wheel in that wide of a rim will fit on the front... only skinny 3.5" rims will fit but even then most brands will usually need a small spacer to fit.
My 15x3.5" (1.75" BS) ProStars require a spacer to clear the front calipers.
Did Greg Weld get a skinny to fit without grinding?? Haven't been up on them. Look like a nice wheel though.
