wheels 15x10
Old 08-10-2008, 07:59 PM
35thz28camaro's Avatar
Default wheels 15x10
will 15x10 with a 6.5in back spacing work on a f-body?
Old 08-10-2008, 08:28 PM
DAS1998's Avatar
you wil have to grind the calipers and run a spacer but they will go on there.. how they will look.. they definatly stick out.
Old 08-10-2008, 08:36 PM
i have been looking at the weld's with a 7in BS but they are $246 each, the summit name brand are $126 each but are a 6.5in BS, so i guess they will stick out more than the 7in BS?
Old 08-10-2008, 09:02 PM
Dragwheelz.com's Avatar
the proper offset to sit in the wheel well perfectly is 7.5" of bs.
on a 10" with 6.5" of Bs the wheel will stick out and possibly rub. It will cut into the tire when it rubs. Depending on how your car sits, you may also have to roll your fender lip also.
by the time you grind, spacers, roll the fenders and hope you don't damage the car and then worry about messing up a tire, Its better to spend more and get a wheel that will directly fit.
Old 08-10-2008, 10:58 PM
DAS1998's Avatar
spend the money....
