rubbing w/315/35/17 on 17x11's
Old 10-02-2008, 03:53 PM
1MeanGreenZ28's Avatar
Default rubbing w/315/35/17 on 17x11's
Just wandering if this tire size would be ok to run on my 17x11's without rubbing? I have 275/40/17's now but wanting to step up a size if possible. Does it also depend on the brand of tires? I have BFG's right now but looking to buy MT's or Hoosiers. Thanks!
Old 10-02-2008, 08:27 PM
Hennytime's Avatar
mine barely touch the paint on my hoosiers, but they dont eat at the sidewall at all, and if they do...bfh
Old 10-02-2008, 11:25 PM
TXws6's Avatar
yeah it can vary from brand to brand, nittos and the cheapo 315s mostly run very skinny. while BFG KDs and Goodyear GSD3s are some of the wider 315s. What may fit perfect on one car might need some BFH or rolling of the fenders on another...which is nothing to stress about both are easy. Are you at stock suspension still? that will also have alot to do with rubbing. Search is your friend, this thread has been posted weekly almost
Old 10-02-2008, 11:58 PM
mattl31's Avatar
as aforementioned, its going to depend on your car.
BUT
generally, at stock ride height
Nitto, Sumitomo - No rubbing
BFG, Mickey, GSD3, Hoosier - BFH'ing
lowered, i would BFH and roll the fenders to be safe on all of the above. no sense in buying new tires and potentially ruining a sidewall.
my BFG Drag Radials took a moderate amount of BFH'ing to make ME feel comfortable. others opinions may vary. this also might be a good time to look into an adjustable panhard bar. it will allow you to center up your rear axle and also stiffen up the rear end and reduce the chance of rubbing.
hope this helps!
Old 10-03-2008, 12:01 PM
WS6R6's Avatar
I have 315/35/17 Sumitomo's for the street and I cut off the bump stops, BFH'd, and now I need to roll the fenders soon because it cuts into the sidewall when I hit a minor bump with a passenger(s) in the rear. I would just do all of these in percaution because all it can do is help!!
Old 10-03-2008, 01:48 PM
Do you guys recommend me stepping up a size or is the 275/40/17's ok? just wandering. I also have stock suspension.
Old 10-03-2008, 02:49 PM
jam99's Avatar
The nittos aren't bad maybe once in a while it will rub. My Mt's rubbed and cut a bunch. But they were way better at the track.
Old 10-03-2008, 04:58 PM
copteezer496's Avatar
315's are the way to go. Wh8ich ever tire you decide to go with, go ahead and roll the fenders just so it'll save you any future headaches. I've had 315's on my car for about 5 years and run a few different tires, never had any trouble. Just don't do a 2" drop to your car and you'll be good.
Quick Reply: rubbing w/315/35/17 on 17x11's
