wantin to run 19's in the back???
im looking at running a 19" by 10.5"-11.0" wide with a 315 tire in the back...will this rub???
car is lowered about an inch, right now i have 18" by 10.0" wide with 295's and they do not rub.
p.s. i do have the stock springs to give it a little height but dont really want to sacrifice stance for wheel/tire combo.
what do yall think?
what do yall think?
You will need to do the BFH mod and roll you fender lips. Also cut you bump stops so you don't have to jack up your car by the axle. I'm running 285/35/r19 with only BFH, with 0 rubbing and 55mm offset is the key!
I am looking at the C5 Z06 rim "19*11 rear but the ofsett is 64mm.
Would it work to use a "9mm spacer and do the BFH mod to the inside of the wheel wheel?
I got rolled fenders allready since i bought the car with "17*11 with Huge 335's. (and yes they did rub!!)
