Time for wheels
Time for wheels
Any vendors got a set of wheels that will work on an m9 rear with wilwood drag disc brakes and 5/8" studs shaft on studs is 11/16". Lugs sent from moser ar open type with flat washer on contact surface. Front is stock so would like a 15x4 and use a spacer. Rear would like to use as close to a 15x10 as possible. Any suggestions would be greatly appreciated
